🎉Community Raffle - Win $25
Join and Win
Shape Optimisation error
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am getting this error in performing shape optimisation. Cai I know why I am getting this?
 **                        OptiStruct 12.0.212                         **
 **                  Design and Optimization Software                  **
 **                   from Altair Engineering, Inc.                    **
 **        Windows 7 Workstation  SP1 (Build 7601)  MEN-PC5209         **
 **          8 CPU:  Intel® Xeon® CPU E5-1620 0 @ 3.60GHz          **
 **                        CPU speed  3600 MHz                         **
 **                    9650 MB RAM,  32617 MB swap                     **
 ** Build tag: 0688910_5533120_Ce64RBW8UH12M:83688-000  4000000004000  **
 **  COPYRIGHT © 1996-2013                 Altair Engineering, Inc.  **
 ** All Rights Reserved.  Copyright notice does not imply publication. **
 **         Contains trade secrets of Altair Engineering, Inc.         **
 ** Decompilation or disassembly of this software strictly prohibited. **
 *** OptiStruct defaults set from:
   install config file: C:\Program Files\Altair\12.0\/hwsolvers/optistruct.cfg.
 NOTE # 9199
 MSGLMT=STRICT is active, all messages will be printed.
 You can suppress some less important warning messages by use of
  MSGLMT=BRIEF or UNREF (in config file or in the input data).
 1 PARAM(s) were set:
    CHECKEL ,NO
 *** See next message about line 2109773 from file:
     F:/New optimisatin/1/run1.fem
  'CTETRA    762986       0  246586    9426    9422    9423'
 This line was interpreted as:
 2109773:CTETRA, 762986, 0, 246586, 9426, 9422, 9423
 *** ERROR # 1000 *** in the input data:
 Incorrect data in field # 3.
  Expected INT > 0, found  INTEGER (0).
 *** See next message about line 2109774 from file:
  'CTETRA    762985       0  265163  181999  182000  132385'
 2109774:CTETRA, 762985, 0, 265163, 181999, 182000, 132385
 *** See next message about line 2109775 from file:
  'CTETRA    762984       0  216315  252454  206422  212897'
 2109775:CTETRA, 762984, 0, 216315, 252454, 206422, 212897
 *** See next message about line 2109776 from file:
  'CTETRA    762983       0  170857  207340  199941  243653'
 2109776:CTETRA, 762983, 0, 170857, 207340, 199941, 243653
 *** See next message about line 2109777 from file:
  'CTETRA    762982       0  142391  244486  149158  142392'
 2109777:CTETRA, 762982, 0, 142391, 244486, 149158, 142392
 *** See next message about line 2109778 from file:
  'CTETRA    762981       0  134198  246452  222030  220510'
 2109778:CTETRA, 762981, 0, 134198, 246452, 222030, 220510
 *** See next message about line 2109779 from file:
  'CTETRA    762980       0  507899  547696  490468  538040'
 2109779:CTETRA, 762980, 0, 507899, 547696, 490468, 538040
 *** See next message about line 2109780 from file:
  'CTETRA    762979       0  252555  190641  155900  278723'
 2109780:CTETRA, 762979, 0, 252555, 190641, 155900, 278723
 *** See next message about line 2109781 from file:
  'CTETRA    762978       0  204486  298774  210444  198028'
 2109781:CTETRA, 762978, 0, 204486, 298774, 210444, 198028
 *** See next message about line 2109782 from file:
  'CTETRA    762977       0  331341  263043  309313  267951'
 2109782:CTETRA, 762977, 0, 331341, 263043, 309313, 267951
 *** More of ERROR messages # 1000 were suppressed...
 *** See next message about line 2119772 from file:
  'CTETRA    752987       0  235663  114018  114015  113997'
 Too many error messages. Aborting run.
 Current limit is 10000. Use 'MSGLMT' control card to change this value.
 Following warning messages appeared too many times
 and were suppressed:
    1000
 Total of 9989 repeat error message(s) were suppressed.
 To see more messages use 'MSGLMT' control card in the data or config file.
1 - 4 of 41
    Altair Employee
    OP
    This seems to be a formating problem? .. but it interprets it correctly - so it seems to me..
    thats the mistake. There is no property assigned to some elements (PID = 0).
    if you have elements that are 'unused' i think you need to delete them. all elements need a proeprty (linked to a material data, ...) assigned.
    Altair Employee
    OP
    Swapnil,
    Make sure you have assigned the compatible property to the elements. In your case PSOLID should be assigned to CTETRA elements.
    Altair Employee
    OP
    Swapnil,
    dear bro how and where we can assign the PSOLID to CTETRA elements?
    Altair Employee
    OP
    Hi Waqas,
    Organize solid elements into a component and assign PSOLID property to the same.
