How to drag nodes (edge) to create shell mesh?
Altair Community Member
Updated by alpha_21885
I want to create ribs for my plate (Shell mesh) using drag nodes or edges as below.
I try but not found this in SL?
Any comment will be appreciated.
1 - 3 of
31
Hi,
Extend tool wont work for your case. Please use Geometry > Body > Create > Extrude tool, Vector with edge input. Refer attached video
KamalRaj
Senior Application Engineer
Altair | Nasdaq: ALTR
kamalraj.rajagopal@altair.com | altair.com
Connect with us: LinkedIn | Twitter | Facebook
#OnlyForward
SimLab learning center (SLC): https://web.altair.com/altair-for-simlab-learning-center-trls
OPUpdated by alpha_21885
Thanks Kamalraj for your great support. I can extrude edges successfully.
I found some options here but it does not work
