🎉Community Raffle - Win $25
Join and Win
Error executing AcuSolve
Hi everybody,
I’m new to AcuSolve. I have to do a CFD analisys (steady state) of a cooling fan of a coaxial pumping unit (the fan of a piston compressor), but i don’t understand why the analisys doesn’t reach the convergence and it finisches after several step (462) with an error (“error occured executing AcuSolve”). I have considered more inflow sections and more outflow sections, and the fluid inside the control volume is divided into two parts, a part around the fan (to assign the reference frame) and the part inside the carter (the control volume is a portion of the carter of the compressor).
I exported the model from hypermesh to acuconsole, and in acuconsole i set the following parameters:
             Analysis type: Steady State;
             Flow equation: Navier Stokes;
             Turbolence equation: Spalart Almaras;
             Fluid: Air (I left the default parameters for the air)
             At the fan i assigned a wall condition
             Reference frame (2850 rpm) assigned to the fan wall and to the fluid modelled around the fan
             Max time step= 1000;
             Convergence tollerance =0.01 (looking at the residual ratio i’ve seen that it doesn’t fall under 0.1)
I want atmospheric pressure in the inflow and outflow section, so in the “Simple boundary condition” i set pressure=0.0 N/m^2 for inflow and outflow(i suppose that 0.0 is the atmospheric pressure) and i’m interested to calculating the mass flux at the outflow.
This is the first time that i do a cfd analysis and it’s problably completely wrong, so i would be really happy if you helped me. I suppose that my mistake was to consider two different fluid in the control volume (two different geometry), and give to one the reference frame, but i’m not sure.
I post the .hm and .acs files, thanks in advance
Best regards
1 - 4 of 41
    Hi arezzo95,
    due to my experiences your case is strong turbulent, especially at the fan outlet, maybe at your inlet also if the back flows occur around the fan.
    In this case I would build extensions for both, system inlet and outlet in order to get a fully developed flow on both sides. You can also create two interfaces, you dont have to seperate their names/parts, I mean: one fan inlet and outlet, to examine, for example fan inlet pressure or mass flow, ....
    Best regards
    Hi raskolnikov,
    Thanks for your answer, therefore i have to extend inflow and outflow section, but in this case i should set a 'slip' condition in the entrance and exit area and not a wall condition, so there isn't friction force and the air is free to slide on this 'artificial' Surface,  isnt't it? Anyway i try to do the analysis in this condition and i let you know as soon as possible.
    Best regards
    acuproUser: "acupro"
    Altair Employee
    Updated by acupro
    Rather than having several inlet and outlet surfaces, you'll have better luck with a single inlet surface and a single outlet surface.  The fluid will then be able to distribute appropriately to the various openings for the passages.  It would be something like putting the fan inside a pipe or duct for the simulation.
    You may also wish to contact your local Altair support office in Italy.
    Altair Employee
    Updated by acupro
    I forgot to mention the mesh you've included is extremely coarse - only 46 thousand mesh nodes.  A model like this will probably require in the range of 1 or 2 million mesh nodes for good accuracy.
