🎉Community Raffle - Win $25
Join and Win
stress occurred in SHELL & Solid Plate of Same Config
User: "M.karthickraja"
Altair Community Member
Updated by M.karthickraja
Hi all,
        I had modeled a steel  Plates of two Cases of Same config  as shown in fig.
Case :1   2D PLATE  2mm Thickness, F=140N(10N/14 Nodes), constraints at opposite end.
Case :2   3D hex Plate  2mm Thickness with 2 Layer of Mesh, F=140N(10N/14 Nodes), constraints at opposite end.
Clarification required :
               1. Both plates are same in Boundary conditions , dimensions and material property. only the element type varies but why the stress induced is different ?
<?xml version="1.0" encoding="UTF-8"?>Picture3.thumb.png.ca5fbad8b46950e7380aa72f73580ca0.png
1 - 2 of 21
    User: "PrasannaK"
    Altair Employee
    Updated by PrasannaK
    Hi,
    In dynamic analysis when the geometry is borderline between the classification of 2-D and 3-D geometry, 2-D shell elements are preferred over 3-D. This is because shell elements being less stiffer captures the mode shapes accurately and with a fewer number of nodes and elements.
    Also, in FEA the result depends on element type and mesh refinement of the model. Thus you are getting variation in stress values.
    User: "Robert Lawson"
    Updated by Robert Lawson
    M.karthickraja -
    If you look at corner stress data instead of centroidal stress data, you will likely find the results are much closer.
    - Robert
