Hi all,
I had modeled a steel Plates of two Cases of Same config as shown in fig.
Case :1 2D PLATE 2mm Thickness, F=140N(10N/14 Nodes), constraints at opposite end.
Case :2 3D hex Plate 2mm Thickness with 2 Layer of Mesh, F=140N(10N/14 Nodes), constraints at opposite end.
Clarification required :
1. Both plates are same in Boundary conditions , dimensions and material property. only the element type varies but why the stress induced is different ?
