Visualize the thickness of the Shell Elements looking to the results in INSPIRE Form
Dear Ladies an Gentleman,
Hallo Community,
I have a question to Altair INSPIRE Form.
I have a Depp Drawing Simulaltion with two Blanks. The Simulation runs with Shells. Within the Postprocessing I can see the Stresses, Deformation etc. for two Blanks as Shells.
My Question: Is ist possible to see the Elements in 3D when looking to the results. The target is to visualize the thickness of the elements.
The target is to prepare a Joining Simulation "Clinch - Clinching". When the two sheets are pressed into the Die, I want to see the undercut. To see the undercut of the two blanks (sheet metall) need to visulalize the elements in 3D.
Please let me know if you have a solution to my question.
Thank you very much & Kind Regards, Ziad
I don't think this is actually possible in the current release. I don't remember Inspire having the 3D visualization capability, yet.
Maybe a suggestion, if you have HyperWorks in your machine, would be to import the .sta files outputted from your analysis into HW, and there I believe you would be able to visualize it in 3D. Have to test this approach.
