More powerful 3D plot processing and animation with Flux
Hi,
I need a more powerful post-processing tool for Altair Flux.
For example, an animation for the 3D plot on a surface temperature.
Also, is it possible to be in the GUI also have a dynamic animation when I rotating the my simulation model?
Wonder is there any interface between Altair Flux with the Hypergraph? Something like that.
Kind regards,
Jerome.
1 - 4 of
41
Hi Abdesssamed,
Thanks for replying.
However, the dynamic animation I talked about is, is there a way that after the animation is created.
I am still able to rotate the model while the animation is playing?
Regards,
Jerome.
Hi,
You are welcome.
Yes, once the new animation is created, behind Flux create a file. this file is saved in the same folder as your Flux project
Best regards.
1 - 1 of
11
Hi,
In Flux there is a way to create an animation once the project is solved. To do it :
About the interface between Flux and Hypergraph, in Flux there is a possibility to create h3d file. To do it:
Best regards.
