More powerful 3D plot processing and animation with Flux
User: "jerometeoh917"
Altair Community Member
Updated by jerometeoh917
Hi,
I need a more powerful post-processing tool for Altair Flux.
For example, an animation for the 3D plot on a surface temperature.
Also, is it possible to be in the GUI also have a dynamic animation when I rotating the my simulation model?
Wonder is there any interface between Altair Flux with the Hypergraph? Something like that.
Kind regards,
Jerome.
1 - 4 of 41
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    In Flux there is a way to create an animation once the project is solved. To do it :
    • Solve the project
    • Select: create new animation (see attached picture)
    About the interface between Flux and Hypergraph, in Flux there is a possibility to create h3d file. To do it:
    • Create a solving scenario
    • In the solving scenario, select HyperView export (you can select the performances that you want to export)
    • Once the solving is done, Flux generate a h3d file that you can open with HyperView
    Best regards.
    User: "asoualmi"
    Altair Employee
    Accepted Answer
    Updated by asoualmi
    OP
    Hi Abdesssamed,
    Thanks for replying.
    However, the dynamic animation I talked about is, is there a way that after the animation is created.
    I am still able to rotate the model while the animation is playing?
    Regards,
    Jerome.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi Abdesssamed,
    Regards,
    Jerome.
    Hi,
    You are welcome.
    Yes, once the new animation is created, behind Flux create a file. this file is saved in the same folder as your Flux project
    Best regards.
