🎉Community Raffle - Win $25
Join and Win
Can HyperView read material data from Abaqus input or odb?
Hi all,
is there a way to read the data of abaqus material cards into HyperView? I would like to create a Reserve Factor in Derived Results for all the elements by simply dividing material allowable by vonMises. Therefore it would be great to read the allowables directly from the abaqus cards. Or is there a way to assign the allowables to the different materials in Hyperview? Goal would be to use only a single expression in expression builder using the model library.
Thanks!
Regards Max
1 - 3 of 31
