(Beginner) How to load pressure on the thin face of PSHELL
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
I made a simple square(500mm x 500mm) pshell with a thickness of 5mm.
I need to load a tensile pressure (1kN/m^2 = 0.001N/mm^2) on each thin faces of the shape, which will stretch my square side-to-side.
But using the pshell, I can't select on the thin face of the shape.
How can I load a pressure then?
<?xml version="1.0" encoding="UTF-8"?>post-41368-0-99252400-1447575517_thumb.j
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2015
    In case of pshell, instead of PRESSURE, you have to apply linear FORCE (N/mm).
    Approximately, when your load is far enough from the hole, you can apply nodal equivalent force (N) on each thin face.
Welcome!
Welcome!
