I made a simple square(500mm x 500mm) pshell with a thickness of 5mm.
I need to load a tensile pressure (1kN/m^2 = 0.001N/mm^2) on each thin faces of the shape, which will stretch my square side-to-side.
But using the pshell, I can't select on the thin face of the shape.
How can I load a pressure then?
