Altair RISE
Nominate Yourself Now!
element deformation contour plot visulazation
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear All,
Please revert on following queries
I'm pressing circular ring into hub by using rigid plate.
1. Is the element deformation shows right color pattern?
2. Should i need to go for higher order element?
3. Should i need to fine the mesh?
image.png.b813204b9092bd1f28508f0e7a47bab5.pngimage.png.54a90112d7272204a15d9edfe85e4ac8.png
1 - 30 of 311
    Altair Employee
    OP
    @Ganesh Munge
    Since the information available is very less to judge,
    Can you refine the mesh at contact surface and check if that helps?
    Altair Employee
    OP
    Dear Prakash, this is the previous analysis results of same type of analysis.
    here, I havent used R body element for pressing plate.
    but in above case, i used. all other things are same.
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    Hi
    How did you model you rigid element? I mean which nodes you selected for rigids?
    Altair Employee
    OP
    Grey part, pressing plate
    mater node= pressing plate arc center
    slave nodes= all pressing plate nodes
    Altair Employee
    OP
    @Ganesh Munge
    I think having a rigid will change the stiffness on contact and this is what makes the difference.
    What is the Istiff on contact card with and without Rigid?
    Altair Employee
    OP
    ring and housing are elastic
    type 24
    p14_solid
    but time step is different
    0.1 sec= 20mm disp
    0.01sec= 10mm
    What energy plot says?
    Altair Employee
    OP
    I kept it default
    I mean what is behaviour of energies? Kinetic internal and hourglass?
    type 24
    p14_solid
    0.1 sec= 20mm disp
    0.01sec= 10mm
    Didnt get it? Time step?? or the end time you want to say??
    Altair Employee
    OP
    @Ganesh Munge
    Can you try with Istif 5 or 6 with Rigids?
    type 24
    p14_solid
    0.1 sec= 20mm disp
    0.01sec= 10mm
    Clearly you are loading with rapid velocity in second case, In second case you are getting this element distortion?
    Altair Employee
    OP
    @Prakash Pagadala
    sure i'll try it out.
    @Nachiket Kadu
    there are two cases
    1. with rigid
    2. with out rigid.
    geometry is different in both cases but phenomenon is same.
    for first case
    disp curve is
    X                  Y
    0sec           0mm
    0.1 sec       20 mm
    for second case
    X                  Y
    0sec           0mm
    0.01 sec       10 mm
    my question is will time step result into such elemental behaviour?
    @Prakash Pagadala
    @Nachiket Kadu
    there are two cases
    1. with rigid
    2. with out rigid.
    for first case
    disp curve is
    X                  Y
    0sec           0mm
    0.1 sec       20 mm
    for second case
    X                  Y
    0sec           0mm
    0.01 sec       10 mm
    are you doing an impact analysis or an quasi-static analysis? I think it sholud be a case of quasi static analysis. Surely what you are giving as loading time is too rapid. I suggest you take default value of 0.3 for your loading and check the results.
    what is the energy error you are getting for the simulation?
    Altair Employee
    OP
    @Nachiket Kadu
    I'll revert on energy plot,
    having licencing error, server is down.
    Thanks guys for the support.
    Altair Employee
    OP
    Dear @Nachiket Kadu
    Please have a look on energy plot
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.62ff64e81668a4102d0f6b7fc7d42a67.png
    Dear @Nachiket Kadu
    1.Make changes in property and try using QEPH formulation to aviod hourglass energy.
    2. Give your loading gradual to avoid sudden impacts you may consider to give the end time as 0.3.
    Apply these changes and check the results. You please go through the previous content for Radioss regarding energy error and troubleshooting techniques.
    Altair Employee
    OP
    @Nachiket Kadu @Prakash Pagadala @George P Johnson
    I want to check pressing force required to insert ring into hub,
    I have simulated 1/4th geometry.
    and got x N of force.
    and suppose, i have full geometry, what will be the pressing force?
    will it be 4 times of first case or same?
    Yes, we can sat that reaction forces are proportional to size of the component.
    Altair Employee
    OP
    you mean it will be 4 times, Right.
    Altair Employee
    OP
    Hi,
    Try these workarounds:
    Hourglass seems to very high in the model.
    For solid elements use Isolid-24 and if any shell elements are there use ishell-24 and N-5.
    For the contact keep Istf to 4, so that minimum of master and slave will be calculated. Also give a minimum stiffness (Stmin-1000N/m). Plot the global contact energy also.
    Ramp the load in 300 milliseconds so that the solution will be stable.
    Once these changes are done, run the simulation and plot the hourglass energy for each part so that we can see which part is contributing more.
    And finally make sure correct material type and parameters are used.
    Which material is used for this?.
    Altair Employee
    OP
    @simulation explicite
    Thanks for the suggestions,
    Bearing steel is used for ring, and aluminium is for housing.
    Altair Employee
    OP
    what if I have tetra elements?, will Isolid  -24 work?
    Altair Employee
    OP
    Hello,
    Isolid is to choose hex element formulation, whereas I_tetra option is used to select the tetra element formulation. Isolid will not be considered if you choose for Tet elements
    Altair Employee
    OP
    will it be fine for hex?
    Altair Employee
    OP
    Yes, seems fine, but disable Icpre option.
    User: "Karthic_22061"
    Updated by Karthic_22061
    Hi Ganesh,
     Yes, Isolid 24 with physical stabilization will take care of hourglass issue.
    Initially try the problem with out FRICTION and look for energy plots. check for the internal, K.E, hour glass& contact energy
    Check with the material properties
    Altair Employee
    OP
    Dear All,
    i'm doing pressing analysis, as said above, i ramp up the load at 0.3 sec.
    used Isolid24.
    but still simulation showing weired behaviour
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.4d20c50b94ad0649c1b62b786901b8b6.png
    Dear All,
    used Isolid24.
    @Ganesh Munge
    You can see that houglass energy is still high. This model is going into hourglassing mode. What element formulation you are using? If you are using underintergrated elements, your hourglass energy should be as minimum as less than 5-10% of total energy.
1 - 30 of 311
