I am running a transient dynamic solution with enforce displacement. Is that possible that i am able to run my solution for 3 second with bigger timestep and then finer timestep for the next 3 second?
Hi,
One of the commercial support members will get in touch with you.
Please Note: If you are a commercial customer, you can contact your local support @ http://www.altairhyp...ortProduct.aspx
