Altair RISE
Nominate Yourself Now!
Error 1499
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
When I run a 3D analysis, I keep getting the below error.  I can't figure out what it means.  I feel like I've check everything and I should be good.
*** ERROR # 1499 ***
 Syntax error in the input file.
*** Run terminated because of error(s) in the input data.
Thanks
-Dave
1 - 4 of 41
    Altair Employee
    OP
    Disregard, had warning control card set to off.  However, I still get this error below:
      *** Problem(s) found while reading line 632818 from file:
          D:/WalkerThesis/Airfoil/NACA23015/Version2/Shape_meshed_3.fem
       'SPC            1       0  12345 0.0'
      *** ERROR # 1000 *** in the input data:
      Incorrect data in field # 3.
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hello
    field 3 should refer to a node ID, in your case is '0' - illegal
    Altair Employee
    OP
    Hi davewalker348
    Looks like you missed selecting a node/Grid point while creating SPC or selected a temp node which was deleted later.
    Please recreate SPCs
    Altair Employee
    OP
    Got it to work, thanks
