Using PSHEAR
Hi,
I tried to use PSHELL with an 2D automesh but it does not work. I receive this message every time I try to process (' CQUAD4 element number 1 references a missing property ID 1 or uses property of incorrect type for this element type. Error # 14 appeared total of 2635 times.'
I am sure that the property one exists and that my elements are assigned with it, but I don't know why it does not work! Also, when I change from PSHEAR to PSHELL it works, but I don't want to use the PSHELL because of the bigger complexity on the Analysis.
Thank you,
Jorge
I've taken all TRIA3 out! But there still one problem!
I tried adding or changing the constraints, but it still not worked. I have also tried making the shell larger, but there was the same problem. Do you have an idea what is happening?
Thank you for helping!
Hi Jorge
what are you simulate???
if you use CSHEAR perhaps you will include a reinforcement because these elements cannot support membrane force
if so then you connect the CSHEAR panel with reinforcement to constraint trans dofs
or set the value F1 F2 in PSHEAR will take affect same as reinforcement rods
Hi Jorge
try switching CQUAD4 to CSHEAR
PSHEAR used only with CSHEAR
