I tried to use PSHELL with an 2D automesh but it does not work. I receive this message every time I try to process (' CQUAD4 element number 1 references a missing property ID 1 or uses property of incorrect type for this element type. Error # 14 appeared total of 2635 times.'
I am sure that the property one exists and that my elements are assigned with it, but I don't know why it does not work! Also, when I change from PSHEAR to PSHELL it works, but I don't want to use the PSHELL because of the bigger complexity on the Analysis.
Thank you,
Jorge
