Error #720
There were 3 error messages during input processing.
The first message is repeated below:
*** ERROR # 720 ***
Invalid static SUBCASE that has no load or enforced displacement.
subcase id = 1
==== End of solver screen output ====
This error appears when I add a secondary force or constraint onto multiple sections of my model. Any help is appreciated.
1 - 10 of
101
Hi,
I didn't receive any model in my dropbox.
Please use the below link to share: https://ftin.india.altair.com:8443/filedrop/~BDR1DN?_ga=1.141452977.26683431.1427861035
hey, i have the same error and can´t fix it.
my model is below.
thanks
I have a similar problem.I was trying to create two load collectors to diferent forces using the load collectors of constraint and a loadadd with all forces.But,for some reason,I have obtained this error.So,wath i did,and recommend you try is open the .fem arquive with the block note and check in the subcase part if the load is defined(probabily not) and to correct this add a text with the load manually as in the attached picture definig the id of the load.
HI luongo1,
Make sure when you add new loads, constraints are under right load collectors.
For instance, you cannot have constraints in Force load collector and the same is used in loadstep for load.
