1 - 30 of
461
Hi Prakash,
I have to do topology optimisation on rear bulkhead plate, from last years design I ran the analysis to find compliance, I put the compliance values and I tried two different objectives but I am not able to get the correct results, I do not know what to do anymore, I have tried everything there more ways that I have tried but still I am failing to get the results. I have uploaded 2 files. When you have time can you please have a look and tell me what I can do. Also my team manager wants me to use Extrusion as one of the design variable for water jet cutting and Draw design variable for CNC, and I do not know how to use either, when I do I do not get any results.
I also also uploading a picture of the final design from last year so that you can have a better understanding of what it should look like.
Hi,
I am attaching the files that I got this information from
Hi Prakash,
I think my units were not correct. I changed my units, and I ran the optimisation again. I believe that I am getting close to the results but I am not sure. I still need to make improvements and if you have a look at the attached files and tell me what I could do to make it better. I think I should use the draw or extrusion function but I don't know how to use them properly.
Regards,
Sufian
1 - 30 of
461
Hi SUf92,
Please refer to the below Tip and Trick:
http://www.altairuniversity.com/wp-content/uploads/2015/10/Design-iteration_increase.pdf
