Radioss:Warning ID 312 Incompatible Kinematic Conditions
1 - 3 of
31
Incompatible kinematic condition occurs when more than 1 kinematic conditions are added to a same degree of freedom. Regarding your case, imposed velocities are added to the slave nodes of TYPE 2 interface.
Thank you, warning:312 has been resolved.
However, when I run the calculation on the following model, the energy error suddenly goes to 99.9% in the middle of the calculation and the calculation terminates with the following error message.
"RUN KILLED: ENERGY ERROR LIMIT REACHED."
Do you know the cause?
What kind of prroblem do you want to solve?
If you want to solve fluid flow, please refer following examples:
RD-E: 3900 Biomedical Valve (altair.com)
