Altair RISE
Nominate Yourself Now!
Optistruct
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I wanted to check, when I run optistruct for topology optimisation, I receive a message after 30 iterations that maximum iterations has reached, and design is infeasible.
What do I do from here, Can I increase the number of iterations.
31 - 46 of 462
    Altair Employee
    OP
    Hi Prakash,
    What am I doing wrong?
    Altair Employee
    OP
    Hi,
    reduce the iso value and I suggest you to have a look at the attached model and play around with the topology parameters like volume fraction UB and LB, member size, etc...
    Altair Employee
    OP
    Do you think that my member size values are too big?
    Altair Employee
    OP
    Hi,
    You have to make a decission about the member size. Usually without member size solver gives a results which may have very thin members. This is not desired as it maybe difficult to manufacture such structure, eventhough it is possible the members may fail during operation.
    Altair Employee
    OP
    Hi Prakash,
    When I chose weighted compliance, it gives me the option to select the load cases. Here should I put the compliance values that I found from doing FEA on the last years design and also it doesn't have the green select button, like it usually does in compliance option.
    Altair Employee
    OP
    Hi Prakash,
    I am not sure, that by making the volume fraction as dconstraints and weighted compliance as objective is the right way to do it. because it doesn't give results which are similar to the previous bulkhead that I have attached.
    Altair Employee
    OP
    This is the result I am getting by doing it the way you have told me.
    Altair Employee
    OP
    Also I noticed from the file that you gave me to play around with that the material properties have changed.
    <?xml version="1.0" encoding="UTF-8"?>origian material properties that where calculated.png
    <?xml version="1.0" encoding="UTF-8"?>material properties from the file prakash gave.png
    Altair Employee
    OP
    Hi Prakash,
    How do I save the optimised results as IGES file?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Use Post page : OSSMOOTH  option for same.See attached screenshot.
    Regards
    Rahul R
    Altair Employee
    OP
    Hi Rahul,
    I tried doing that but I don't have a .grid file.
    Altair Employee
    OP
    Rahul and Prakash,
    Can you please help me understand how to save the results as IGES. I tried doing it the way Rahul said but it doesn't let me cause it say that I need to upload a .grid file.
    Altair Employee
    OP
    Hi,
    Turn off the Grid option. Change the option from AutoBead none to avoid. You dont need a .grid file.
    Altair Employee
    OP
    Hi Prakash,
    Thank you so much.
    Altair Employee
    OP
    Hi Prakash,
    I have a quick question. In which units does Hyperview display results that I have attached below. If my The forces and length are in N and mm, while the material young modulus is in MPa, and density is in t/mm^3
    Is the displacement result in (mm)?
    Von mises is it in (MPa or psi)?
    yes displacement would be in mm & Stresses in MPa or n/mm2 asper above mentioned units.
    HV doesnt follow units system.whatever units consistency you have maintained according you would get results.
    Regards
    Rahul R
31 - 46 of 462
