Retrieve Multi-Material Model with OSSmooth
Hello,
I have run a Multi-Material Analysis which uses two different materials. I am hapy with the result, and now I would like to retrieve the model of one of the materials.
Is this possible? I know hoe to retrieve a model with a certain density threshold value via OSSmooth. In this case though, the element densitys can't be used. Can OSSmooth also refer to the material value?
In the pictures I would like to retrive the orange&red part of the model, thereby getting rid of the blue area.
Best regards,
Benjamin
1 - 1 of
11
Does anyone know a way to solve this problem?
Best regards,
Benjamin
