🎉Community Raffle - Win $25
Join and Win
What unit is the accn.?
User: "karth"
Altair Community Member
Updated by karth
Hello,
Pl find attached image of the acceleration output wrt frequency.
My model is in 'mm' units and the material properties are all specified in in N, mm (except for the density, which is specified in tonne/cu.mm)
So, in the attached image file, the magnitude of max. acceleration that I obtained is 5400 along Y axis.
This should be 5400 mm/sq.s. So, 5400/9810 = 0.5 g is the magnitude.
Am I right?
Pls share your views.
1 - 2 of 21
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Karth,
    The solver is unit neutral so it is up to designer or user to maintain unit consistency.
    User: "karth"
    OP
    Updated by karth
    ok. Just for confirmation, in the above example, mm/sq.s is it right ?
