Pl find attached image of the acceleration output wrt frequency.
My model is in 'mm' units and the material properties are all specified in in N, mm (except for the density, which is specified in tonne/cu.mm)
So, in the attached image file, the magnitude of max. acceleration that I obtained is 5400 along Y axis.
This should be 5400 mm/sq.s. So, 5400/9810 = 0.5 g is the magnitude.
Am I right?
Pls share your views.
