🎉Community Raffle - Win $25
Join and Win
CONVERSION THE INPUT FILE TO OHTER-READABLE FORMAT
User: "aykut sumer"
Altair Community Member
Updated by aykut sumer
Hello
I have got a finite element (hm) prepared by second-person. The finite element model has been built on property of related part. when ı switch  to component , All the component does not have any property assigned to them. but when ı use property everything looks okey assigned for each component.
As a solver ,ı have used the MSC Nastran.
The problem ı faced is that bdf file,which is input file for MSC Nastran,does not have any property assigned to component. Therefore, the patran is closing itself for unclear statmement given in bdf.
please can you explain how to change   from property-based mesh to component-based part?
component based:''each component has got it's property assigned to it''
best regards
1 - 1 of 11
