1 - 4 of
41
Can you check the magnitudes of forces/moments applied in your model, maybe that is causing the model fly away?
you can share the model with us, if you still face the problem.
use the dropbox link in my signature to share the model.
Hi spring
Check if you had constrained the model properly. This could be one of the reasons in your case.
