Constraints with stopper
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hallo all,
I woder how can i analysis the part in this case. the 3D part ist constraint in middle hole in the first 5 DOFs, that means it can be rotaed along Z axial under loads, the force is worked on the right side hole. on the left side there is a stopper, it sppose to be a rigid body and constraint in that position.
The question is in this case how can i set up the constrains between the part and the stopper, which Funktion should i use and how? for examples: Interfaces, rigid walls, blocks, contactsurfaces?
If anyone could give me some advices or toturials, it would be very heplful and i apperciate it.
Thanks a lot
Best regards
Don
