Please, how can I solve this error?
Raphael Lima
Raphael Lima Altair Community Member
edited November 2020 in Community Q&A
Pleasem I'm doing a Gauge optimization for a part, where I only have one property to optimize.
I have this responses:
Stress -> same as the part property
Displacement -> Part node
Weight Compliance -> 3 load cases, 1g, 3.5g and torsional (displacement applied)
But I have the error below:
Best Answer
  • Viraj_Kulkarni
    Viraj_Kulkarni
    Altair Employee
    edited November 2020 Answer ✓
    Hi Raphael,
    Does your static load case 3 have both force and enforced displacement as loads?
    and are you trying to minimize compliance?
    The error is mostly related to that.
    You can solve the optimization problem if you either have only force or only enforced displacement as load in a sub case.If you can remove either of it you can solve optimization as it is.
    If you need both force and enforced displacement to be as load for sub case 3, you change your response and objective to min mass instead of min compliance. And to make sure you improve your design you can have stress/displacement constraints on individual load cases.
    Here is some more information on how compliance is calculated.
    The compliance definition for load case 3 is creating problem. Once you remove that and substitute with min mass with constraints needed, you should be all set.
Answers
  • Viraj_Kulkarni
    Viraj_Kulkarni
    Altair Employee
    Hi Raphael,
Welcome!
Welcome!
