Hello Friends,
I am trying to analyze impact case with RADIOSS as a solver. For creating material (Carbon Fibre Composite) I used M25_COMPSH as a card image. After that for a creation of property, initially, I used P10_SH_COMP as a card image and finally I applied both property and material to a component. After that, I created plies(without having any core material) of the same material(Carbon Fibre Composite). And when I am trying to visualize plies on the component, I am not getting anything.
But if I am changing the property to P17_STACK, I can visualize plies on the component. So, I kept card image for the property as P17_STACK and proceeded with my work. After setting up the complete environment for simulation, when I am running my task in RADIOSS,it gives me error list, which I am attaching with this question.
So, could you guys help me to solve the errors?
Thank You for your help
