Altair RISE
Nominate Yourself Now!
How to solve this meshing problem in die cating simulation
User: "Pearl"
Altair Community Member
Updated by Pearl
When push the Run command to simulate the dump showed a meshing error. How we can solve this problem? There are the documents in attachment. Thanks in advance.
1 - 4 of 41
    User: "MilanRaval"
    Altair Employee
    Updated by MilanRaval
    Hello,
    It works fine on my end. To understand better why it failed. I would like you to share your setup in Inspire Cast. Here you have shared only CAD model and image that says meshing failed. Based on that I can not provide more information on cause.
    Regards,
    Milan Raval
    User: "MilanRaval"
    Altair Employee
    User: "Pearl"
    OP
    Updated by Pearl
    Hello,
    Regards,
    Milan Raval
    I would be delighted if you could tell me how to share my setup on inspireCast because I do not know exactly what I will do.
    Thank you for your help
    Regards,
    User: "Pearl"
    OP
    Updated by Pearl
    i attached the file. Is this the setup file you would like?
    Regards,
