Clay Render
Hello,
is there any special requirement to activate clay render? ('Enable clay render' is activated of course)
I have tried it with environment switched on or off & with or without extra light source.
The result is always the same... complete black objects.
Thanks for help, best regards,
Mario
- Please extract it and save it to ProgramFiles/Evolve/Evolve 2016.xxxx/MaterialsLib/5/ on PC and for Mac it is Applications/Evolve 2016.xxxx/MaterialsLib/5/
- Restart Evolve and you can see the clay material under a new category 'Stone'
Hello,
thank you for the information...
Best Regards,
Mario
The clay renderer is gone with Evolve 2016 ????
Best regards,
Mario
Hi Lunau,
The clay render feature is from a third party and we ran into several issues in 2015. Unfortunately we could not fix all of them and we made a decision to hide it temporarily.
Unless we can fix all issues with the clay render I do not see it being exposed to end users. Sorry for any inconveniences caused and an alternate is to render it with clay as a material.
Lunau,
I created a quick clay like material using existing evolve resources. Attached is the zip folder containing the material.
The color is RGB 215 138 84 and I used a Roughness map image 'Pave001b.jpg' under the pavements category. You can play around with the reflection, roughness and also the texture positioning to position the roughness map the way you want including scaling.
Hope this helps.
Mario,
For an unknown reason the service pack update for 2015 had an issue with Clay Render. We are working on this issue and will address it as soon as possible.
