Hi James,
From the 2D side, midmesh and rebuild have portions of their code as multi-threaded. It is not user controlled, but happens automatically.
Some tools, such as adaptive tria remeshing, boundary layer and tetra mesher are multi-threaded and uses all available threads by default. Following environment variable will enable user to define no of threads to use. (0.5 means use 50% threads).
M_HW_MT_LOAD=0.5
From a BatchMesh perspective, if you submit parts through Part Browser, each part will run on a different CPU. Also, there is the possibility to change the no of threads directly in the panel.
Hi Rafael,
Where is this ribbon that the batch button (pictured) is in? I haven't seen it in HyperWorks.
Thanks,
Christian
Hi Rafael,
Thanks,
Christian
Hi @Christian Free ,
I think the ribbon for the picture above is from HyperWorks CFD, not in HyperWorks.
Hi James,
M_HW_MT_LOAD=0.5
