Altair RISE
Nominate Yourself Now!
Optistruct Shell to shell connection
User: "Andre1501"
Altair Community Member
Updated by Andre1501
Hey,
Maybe somebody can help me in order solve my issue. How do I connect Shell Elements with Shell Elements in order to model a fillet weld (green=weld). Is there any possibility to not select for every weld each node seperatly in order to create multiple RBE3?
Maybe somebody can help with that.
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    You can do it by connector.
    There is a config of weld with RBE3+hexa+RBE3
    User: "Andre1501"
    OP
    Thanks for your answer. Is there any tutorial About it?
    Or can you please explain the proredure a little bit more in Detail?
    I just started with working with Hyperworks.
    Thanks in Advance.
    User: "tinh"
    Updated by tinh
    Yes
    Examples are in HM help, or on google
    User: "Andre1501"
    OP
    ok, i tried it now using a connector. I used Quads (angeled).
    The connector was also shown green (therefore I thought it is correctly realized).
    Nevertheless during analysis the parts did not interact. I do not get my mistake. Do I have to connect the parts/meshes somehow after creating a connector? I thought that is the taks of a connector?
    User: "tinh"
    Updated by tinh
    Connectors are geom entities. You must verify FE entities.
    Doing an example/tutorial about connector is a good ideal
