Hey,
Thanks for pointing this out.
When I opened hyperstudy, I can see a lot of options but not EDEM. I have attached a screenshot for your reference.
Thanks,
Kiran
Could you try installing the EDEM-Hyperstudy connector again? It maybe the installation order that requires the connector to be installed after HyperStudy not before.
Regards
Stephen
Hi Kiran,
It looks like you are opening the EDEM-HyperStudy connector directly, this connector is installed as an add-in to HyperStudy but needs the base product also. IF you don't have it already you can download HyperStudy from the Marketplace.
Once installed if you open HyperStudy you can access EDEM models as shown in this video - EDEM - How to Calibrate Material Model with EDEM and HyperStudy
Also worth noting that you have the 2022.3 version of the connector installed, you'll have to also use the 2022.3 version of HyperStudy and EDEM with this otherwise if you want to use the latest version you'll need all 3 software to be the same version.
Regards
Stephen
Hi Kiran,
Regards
Stephen
