Analysis values based on what scale
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hai,
I am having a doubt of the values gettig in the result, I have attached a Displacemant contour plot image. The minimum to maximum values are based on what scale. How can we understand the values practically? Let me know
Regards,
Dani
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2016
    Hi @Dani,
    The results scale/units completely depends on the input system you have provided during modelling.
    If you given units are in mm, MG, S then the output units will be mm, N/mm2, etc...
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Input value given Force of 350 Kg in N=3432.327.So these displacement values are in meter or in millimeter?
    Regards,
    Dani
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Dani,
    Basically HyperMesh is unitless. You need to maintain a unit consistency. If the given length, breadth, width is in mm, then your displacement results are in mm. If they are in meters your displacement results should be in meters.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Ok . Thank you for the information :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Regards,
    Dani
Welcome!
Welcome!
