Control Card value on Thermal Analysis
Hi there,
I'm doing a thermal analysis using OptiStruct. I have 32 constrained nodes that require a diferent temperature value. However this value comes from a linear interpolation between the two end nodes (one has a 0ºC temperature and the other 4,5ºC temperature). Is there any way I can use a linear function for the nodes in Card Edit?
If you are OK without SPCs you can use TEMPERATURE panel to create temperature entries with linear interpolation,
My question is: If I use the temperature instead of the SPC does the solver outputs the same results?
Thanks for the help!
Hi @RodrigoFST
Sorry for a late reply, do you mean using temp as load type in same steady-state heat transfer analysis type?
Hi RodrigoFST,
You'll get different results.
Thank you
Hello,
Try to use the following way:
Best Regards,
Mario
