🎉Community Raffle - Win $25
Join and Win
Control Card value on Thermal Analysis
User: "RodrigoFST_22268"
New Altair Community Member
Updated by unknown
Hi there,
I'm doing a thermal analysis using OptiStruct. I have 32 constrained nodes that require a diferent temperature value. However this value comes from a linear interpolation between the two end nodes (one has a 0ºC temperature and the other 4,5ºC temperature). Is there any way I can use a linear function for the nodes in Card Edit?
1 - 6 of 61
    User: "Mario_21478"
    Updated by Mario_21478
    Hello,
    Try to use the following way:
    • Create the load on start and end of line (see picture 1)
    • Switch to 'nodes' as target type
    • Switch to 'linear interpolation' for type of load (default is constant value)
    • Select the nodes between start and end for 'nodes' (e.g. by path)
    • Select the start and end load for 'loads'
    • Press create, a linear interpolation is done and loads are created (see picture 2)
    Best Regards,
    Mario
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7adae6ea9d2921ba18031260204d9f5d.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8a2f982b7d384d409b4ae9bb3d82e6b0.png
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    If you are OK without SPCs you can use TEMPERATURE panel to create temperature entries with linear interpolation,
    OP
    Updated by unknown
    My question is: If I use the temperature instead of the SPC does the solver outputs the same results?
    Thanks for the help!
    Altair Employee
    Hi @RodrigoFST
    Sorry for a late reply, do you mean using temp as load type in same steady-state heat transfer analysis type?
    OP
    Updated by unknown
    Prakash Pagadala
    Yeah, that is my question!
    Thanks
    Altair Employee
    Hi RodrigoFST,
    You'll get different results.
    Thank you
