Control Card value on Thermal Analysis
RodrigoFST_22268
RodrigoFST_22268 New Altair Community Member
Hi there,
I'm doing a thermal analysis using OptiStruct. I have 32 constrained nodes that require a diferent temperature value. However this value comes from a linear interpolation between the two end nodes (one has a 0ºC temperature and the other 4,5ºC temperature). Is there any way I can use a linear function for the nodes in Card Edit?
  • Mario_21478
    Mario_21478 Altair Community Member
    edited May 2018
    Try to use the following way:
    • Create the load on start and end of line (see picture 1)
    • Switch to 'nodes' as target type
    • Switch to 'linear interpolation' for type of load (default is constant value)
    • Select the nodes between start and end for 'nodes' (e.g. by path)
    • Select the start and end load for 'loads'
    • Press create, a linear interpolation is done and loads are created (see picture 2)
    Best Regards,
    Mario
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7adae6ea9d2921ba18031260204d9f5d.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8a2f982b7d384d409b4ae9bb3d82e6b0.png
  • Altair Forum User
    Altair Forum User
    edited May 2018
    If you are OK without SPCs you can use TEMPERATURE panel to create temperature entries with linear interpolation,
  • RodrigoFST_22268
    edited May 2018
    My question is: If I use the temperature instead of the SPC does the solver outputs the same results?
    Thanks for the help!
  • Altair Forum User
    Altair Forum User
    edited May 2018
    Hi @RodrigoFST
    Sorry for a late reply, do you mean using temp as load type in same steady-state heat transfer analysis type?
  • RodrigoFST_22268
    edited May 2018
    Prakash Pagadala
    Yeah, that is my question!
    Thanks
  • Altair Forum User
    Altair Forum User
    edited May 2018
    Hi RodrigoFST,
    You'll get different results.
    Thank you
