Altair RISE
Nominate Yourself Now!
SimLab - Model Brower - How to Display both Solid & Shell models
User: "RandyH"
Altair Community Member
Updated by RandyH
How do you change the settings to request Solid and Tri elements models to appear in the Model Browser at the same time?  At this time only the Solid Element model is displayed.
1 - 4 of 41
    User: "Hakan_20716"
    Updated by unknown
    If you make the following selection in the Tet Mesh window, the 2D and 3D mesh will be listed separately.
    User: "AlessioLibrandi"
    Altair Employee
    Updated by AlessioLibrandi
    Altair Employee
    SimLab, differently from HM, does not require to delete the shells once solid elements are created.
    Once Solid elems are created, shells can still be selected (this is very practical for example to define contacts), but will not be exported and can not receive a property.
    If you need both shells and solids, create a shell body on the outer faces. Use the option "duplicate and make shared faces".
    Altair Employee
    Hakan, this is in theory correct but the two bodies will not share the nodes. Please see before how to create shells sharing nodes with the solid body
