🎉Community Raffle - Win $25
Join and Win
How to check time-step in SL(Radioss/LSdyna)?
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hi,
I am running some drop test for electronic cover parts (Radioss).
However, I have not found any tool to check time step in SL.
May I know your advice on this?
Thanks
1 - 3 of 31
    User: "Nantha"
    New Altair Community Member
    Updated by Nantha
    Hello Alpha
    Can u kindly elaborate on your query.
    Thanks & Regards
    Nantha Kumar N
    User: "alpha_21885"
    OP
    In HM, after assign Material or Property for my parts (2D & 3D), I can check the estimated time step. But I do not know how to do in SL.
    This is very important function for impact analysis to reduce computation time.
    <?xml version="1.0" encoding="UTF-8"?>399901607_nh.thumb.png.e60b6637ffd24f6faed0f96a1d5f8113.pngHope this is clear for you.
    User: "Nantha"
    Updated by Nantha
    Hello Alpha
    Thanks for your explanation.
    Currently in SimLab you can check the time step using the Quality Check tool from Mesh > Verify > Quality.
    After applying Material & Properties, select the bodies and check the time steps based on the appropriate element types.
    Kindly let us know if you have any concerns.
    Thanks & Regards
    Nantha Kumar N
