I am running some drop test for electronic cover parts (Radioss).
However, I have not found any tool to check time step in SL.
May I know your advice on this?
Thanks
Hello Alpha
Can u kindly elaborate on your query.
Thanks & Regards
Nantha Kumar N
In HM, after assign Material or Property for my parts (2D & 3D), I can check the estimated time step. But I do not know how to do in SL.
This is very important function for impact analysis to reduce computation time.
<?xml version="1.0" encoding="UTF-8"?>Hope this is clear for you.
Thanks for your explanation.
Currently in SimLab you can check the time step using the Quality Check tool from Mesh > Verify > Quality.
After applying Material & Properties, select the bodies and check the time steps based on the appropriate element types.
Kindly let us know if you have any concerns.
