🎉Community Raffle - Win $25
Join and Win
How can I end my simulation with a condition on Hyperform?
User: "Kaushely EPASINGHE"
Altair Community Member
Updated by Kaushely EPASINGHE
Hello,
I am working with Hyperform version 2017 and I have small question regarding simulation conditions. I want to form a cylindrical blank using 4 tools (2 on each side of the cylinder). The tools move symetrically. The problem is, I want the simulation to end once the blank touches (circled in red) the 2 tools on the exterieur (tool 1 and 3). See the diagram below for a better understanding. I want to do this without having to define the motion distance for each tool as I do not have the value.
How can I do this on hyperform?
Thank you in advance
Céline
1 - 2 of 21
    User: "Rogerio Nakano_21179"
    New Altair Community Member
    Updated by Rogerio Nakano_21179
    Hi
    I not sure if there is any feature on the HyperForm model setting that does what you need.
    As you are doing incremental forming, you are running Radioss i believe.
    You could user /SENS, and on engine deck the /STOP/LSENSOR.
    If the sensor is activated the analysis is terminated.
    I Hope this is helpful
    Regards
    OP
    Hi,
    Yes I am using RADIOSS to run the calculation. I have never used /SENS. Can you please tell me how to do that? Is there a gude I could follow?
    Céline
