Hello Sir,
I am not getting the error so i attached the .out file so kindly go through it
Thanks and regards
Mahantesh T
Please dont call thermal bc under Load subcase definition for strutural loadstep. Instead apply thermal bc via subcase option TEMP_Load.Also define elastic material property to run through.
Hello Sir,
Elastic material properties like E and Poisson ratio i assigned in material load col, now the file is running but the results r coming wrong, so kindly guide me is there any other options are there to assign elastic properties
Thanks and regards
Mahantesh
I guess this could be because of units defined. What value you have defined in MAT1 and MAT4?
You can request free eBook on OptiStruct Thermal Analysis using below link.
https://altairuniversity.com/free-ebook-thermal-analysis-with-optistruct/
Hello Sir,
I am facing the error 1908 while carrying out the simple thermal analysis for simple beam so kindly help us to solve this error and please find the below attached file regarding the problem
Thanks and Regards
Mahantesh T
Please refer below post.
https://community.altair.com/community?id=community_question&sys_id=f796847a1b2bd0908017dc61ec4bcb3c
Hello Sir,
kindly go through the .out file which is attached below
Thanks and regards
Mahantesh T
Do you have MATT1 card defined inside the MAT1 card. Is that intended or By mistake? If it is by mistake, then please uncheck MATT1 and run analysis again.
MATT4: Defines temperature-dependent material properties for the corresponding MAT4 Bulk Data Entry fields via TABLEMi
Use Table create utility to define Temperature dependent conductivity with TABLEM card.
So if you have defined MATT4 under MAT4 card, call TABLEM card T(K)
Could you please share .out file of the run? Also refer below post.
https://community.altair.com/community?id=community_question&sys_id=f9c648ba1b2bd0908017dc61ec4bcbdd
