.h3d file is not generated
kotian
kotian Altair Community Member
edited October 2020 in Community Q&A
Dear Sir,
i am  working on crash analysis , to study about material behavior  , as my solver run properly , no error found . but .h3d file is not generated
below i attached my engine file input , plss look into  my error and correct me
Welcome!
Answers
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited July 2020
    Hi kotian
    Is it possible to share the files which you are working on.
  • Junta_20361
    Junta_20361 New Altair Community Member
    edited July 2020
    I believe that you are using Radioss solver.
    You need to check your output control card to set the output format to h3d.
    If you are using HyperForm, in default settings, there is a command: -noh3d >> this command set that no h3d file will be create.
    >> you can change the setting by 'preference >> hypeform settings'
    In case you have already completed your simulation and it takes a lot of time for rerun,
    you can use HVtrans to create the h3d file.
    (you will find this tool in start menu >> just key in the name).
    Use HV trans to open animation files (.A001 in the run folder) then select the timestep, result type, components and translate
    It is very easy to use.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.225de09ba7b3be74bc3571d8cfe68f3e.png
  • kotian
    edited July 2020
    As i am new user to hypermesh , just learn the concept behind that, want to  implicate , as i am using student version so  HVtrans tool is not available for me ...
     below i attached  my project file . still i am not  available to generate .h3d file , please look into my doubt
  • Pranav Hari
    edited July 2020
    Hi kotian
    You are not getting the .h3d file because the run is getting terminated when the energy error and mass error limit is reached.
    Open the 001.OUT file and go through the errors and correct it.
    Interface Id 1 is causing the min time step error. Check the reliability of the time step values you imposed here.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.235288c8d4081756e9ff8c5b74cb45cd.png
Welcome!
Welcome!
