water spraying
hi expert,
Can we use AcuSolve to simulate the water spraying phenomenon?
Like below machine:
in this machine, they used a high speed fan at the bottom of the cone shape. the other end of the cone has few nozzle to spray the water out.
With the air flow come from the fan, the water dew travels far from the machine.
I'm thinking of using disperse multiphase for this >> is it possible?
Or is there any other software in Altair can do this?
Thank you!
1 - 1 of
11
Hi,
This is a complex application, that will get increasingly expensive as the resoution needed to capture the small droplets increase. You may end up with a impractical simulation time. However, depending on the objective of the simulation, a simplified version could get some approximate results. If you have more details on the use case you may contact your local support to get more information.
Thanks.
