Hello, I made a CFD mesh using hypermesh to simulate heat transfer from flowing fluid across a pipe wall.
Components created are:
-Steel pipe (solid)
-fluid flowing inside (fluid)
-ambient air outside (fluid, in the form of an enclosure)
-inlet (inside fluid 1 surface end)
-outlet (inside fluid other surface end)
Since I am not quite experienced with Acusolve I chose to work in ANSYS Fluent. I exported meshed file in NASTRAN. Then imported it into Fluent. But in Fluent there are no boundary conditions as 'Inlet' & 'Outlet'. Also certain unknown boundary condition parameters appeared, which I couldn't understand.
I am hereby attaching the graphics window of Fluent for your considerations.
Kindly, help me in knowing if the components I created in hypermesh aren't correct, do I need to create 'Interfaces' too or anything I am missing which must be made to get desired boundary conditions in Fluent.
In anticipation of positive reply.
