importing experimental data
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello forum
HS-1505: Register a Templex Function in HyperStudy
In this Tutorial , tep 5.19  the experimental result  file is imported in *.xy format.  But I have my experimental result file in *.csv form
Problem with importing this is values are not imported as X(frequency) and Y(frf) colums as seen in preview(img2). The actual plot of this values should be as indicated in red line in (compare.pdf)
Is there a way to convert csv to .xy format or import it directly in proper columnwise data.Is there way to chk what data is imported.
Regards
Pratik
<?xml version="1.0" encoding="UTF-8"?>post-36734-0-15151600-1435575442_thumb.j
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2015
    Hi,
    You can save csv in txt format and from notepad you can save the same in .xy format.
    Regards
    Rahul R
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2015
    Hi Rahul
    I was able to create create .xy file but it does not import data as column1(Xaxis-frequency) against column2 (Yaxis- FRF) but column1(Xaxis-rownumber) against column2 (Yaxis- FRF)
    what would u suggest ?
    Regards
    Pratik
    <?xml version="1.0" encoding="UTF-8"?>post-36734-0-95761500-1435761030_thumb.p
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2015
    Hello,
    There is no difference between *xy and *csv, I believe they are using the same reader.  You can always investigate the contents of a vector by defining a response as just the vector name and clicking evaluate in the expression builer.  This is geneate an error because responses cannot be vector, but you can see the contents of the vector.
    You have not shared the contents of you file, but based on what you describe, I suspect  the data you want is simply not the first and second column as you have have requested. Without actually seeing a snapshot of the file contents it is impossible to be more specific.  When he data doesn'y have headers, they are simply labeled with generic names like Column1, for example.
    Thanks
Welcome!
Welcome!
