Remeshing a composite structure
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
For a project of mine, i created a composite structure with different plies and laminates and i applied a mesh with element size 10mm to it.
However after doing some analysis, i would like to refine the mesh to for example an element size of 5 mm to see how accurate my mesh is and if more refinement is needed.
I'm having some issues with remeshing because all the sets that were created when i created the plies, suddenly become empty after i remesh the structure. This leads to errors when i try to execute the analysis.
What would be the correct way to remesh a composite structure without having these problems with the plies and their sets?
King regards
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi @Jeroen DV
    This can be done with Surfaces which is still under testing and should be available soon.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi @Prakash Pagadala
    The problem is that i don't have that much time left to finish my project due to deadlines so is there another workaround that can help me?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi,
    I will check if there is a work around for the same.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    Hi @Prakash Pagadala,
    Have you found a work around yet to achieve the same result?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2018
    @Jeroen DV
    If the plies created with geometry information, on realization of plies should get new element sets. But this is still in infant phase.
    You can give it a try.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2018
    Any news if it is possible yet to remesh a composite structure with surfaces without losing the sets connected to the plies?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2018
    Hi,
    I have raised an RFE for the same. Waiting for the team to develop the same :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Welcome!
Welcome!
