Particle Spacing in nFX Tools
Linux34
Linux34 Altair Community Member
edited October 2020 in Community Q&A
Hello everyone!
I have a quesiton about nFX Tool '1 Click SPH Generation'. The first parameter to be set is the 'Particle Spacing'.
What exactly does this parameter mean and which unit has it?
Thank you!
Answers
  • Santhoshkumar
    Santhoshkumar
    Altair Employee
    edited June 2020
    Hi,
    Particle spacing is the distance between adjacent particles in the global coordinate. The particles are uniformly distributed along the global XYZ axis. This spacing is used when generating the particles for stationary parts, moving parts and the fluid regions.
    The above information I took from SimLab help page. After opening the '1 Click SPH creation' tool, press F1 will take you to the help page about this tool.
    If you are using SimLab 2019.3 or later version, we have introduced unit system in SimLab. Refer the attached image.
    If you are using older versions of SimLab, Specify the value for particle spacing based on model units. For example, if the model imported in Meter, then specify the particle spacing value in Meters. You have to make sure that the units are consistent.
  • Linux34
    edited June 2020
    Hey,
    thanks for your help!
Welcome!
Welcome!
