🎉Community Raffle - Win $25
Join and Win
Licensing problem with Sulis
User: "Eugene Kozhukhovskyy"
New Altair Community Member
Updated by Eugene Kozhukhovskyy
Would like to ask your help for license activation.
I have followed to instructions but without success. The program returns answer "Could not activate license. Hard Disk ID: 14410D7059CB"
What I am doing wrong?
1 - 7 of 71
    User: "Matthieu Pupat"
    Altair Employee
    Updated by Matthieu Pupat
    Hello,
    On opening Sulis, please click on
    then fill in your Altair One username and password
    and finally click on
    Thanks,
    Matthieu Pupat
    OP
    Hello,
    Thanks,
    Matthieu Pupat
    Hi Matthieu,
    Thank you for the reply. I did this. But result you can see below.
    Kind regards,
    Eugene
    Altair Employee
    Hi Matthieu,
    Kind regards,
    Eugene
    Please click on License Log and send us the full output.
    OP
    Activating Sulis...
    Altair One credentials valid
    Altair License Manager: License error
    Feature(s): GlobalZoneEU, HyperWorks, HWSulis
    Error Code: 15
    Error Description:
    [NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server
    Feature: Sulis
    Error Code: 4
    Error Description:
    [LOCAL] .\unins000.dat - (Err: 4) License file is using unknown/invalid syntax
    License Path:
    Altair Hosted HyperWorks Units: License error
    Feature: Sulis
    Error Code: -40
    Error Description:
    [LicID 68551] AU Industrial Designer - (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses
    Feature(s): GlobalZoneEU, HyperWorksEDU
    Error Code: 15
    Error Description:
    Feature: HyperWorksEDU
    Error Code: 15
    Error Description:
    License Path:
    Error Code: -40
    Error Description:
    Error activating Sulis with Altair One credentials
    Unable to activate Sulis
    Altair Employee
    Activating Sulis...
    Error Code: 15
    Error Description:
    Feature: Sulis
    Error Code: 4
    Error Description:
    License Path:
    Feature: Sulis
    Error Code: -40
    Error Description:
    Error Code: 15
    Error Description:
    Error Code: 15
    Error Description:
    License Path:
    Error Code: -40
    Error Description:
    Your license is only valid for use in the Asia Pacific region and it looks like you are trying to access it from Europe/Africa which will not work.
    OP
    I am located currently in UAE as I indicated during the registration of the account. And I am accessing the license from the same location (Dubai, UAE)
    Altair Employee
    Then you might have another issue. I will create a support case so that a specialist can contact you and look into it further.
