On opening Sulis, please click on
then fill in your Altair One username and password
and finally click on
Thanks,
Matthieu Pupat
Hello, On opening Sulis, please click on then fill in your Altair One username and password and finally click on Thanks, Matthieu Pupat
Hi Matthieu, Thank you for the reply. I did this. But result you can see below. Kind regards, Eugene
Please click on License Log and send us the full output.
Activating Sulis...Altair One credentials validAltair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWSulisError Code: 15Error Description:[NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server
Feature: SulisError Code: 4Error Description:[LOCAL] .\unins000.dat - (Err: 4) License file is using unknown/invalid syntax
License Path:
Altair Hosted HyperWorks Units: License error
Feature: SulisError Code: -40Error Description:[LicID 68551] AU Industrial Designer - (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses
Feature(s): GlobalZoneEU, HyperWorksEDUError Code: 15Error Description:[NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server
Feature: HyperWorksEDUError Code: 15Error Description:[NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server
Feature: HyperWorksEDUError Code: -40Error Description:[LicID 68551] AU Industrial Designer - (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses
Error activating Sulis with Altair One credentialsUnable to activate Sulis
Activating Sulis...Altair One credentials validAltair License Manager: License error Feature(s): GlobalZoneEU, HyperWorks, HWSulisError Code: 15Error Description:[NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server Feature: SulisError Code: 4Error Description:[LOCAL] .\unins000.dat - (Err: 4) License file is using unknown/invalid syntax License Path: Altair Hosted HyperWorks Units: License error Feature: SulisError Code: -40Error Description:[LicID 68551] AU Industrial Designer - (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses Altair License Manager: License error Feature(s): GlobalZoneEU, HyperWorksEDUError Code: 15Error Description:[NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server Feature: HyperWorksEDUError Code: 15Error Description:[NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server License Path: Altair Hosted HyperWorks Units: License error Feature: HyperWorksEDUError Code: -40Error Description:[LicID 68551] AU Industrial Designer - (Err: -40) While checking out feature "GlobalZoneEU": Requested feature name was not found in licenses Error activating Sulis with Altair One credentialsUnable to activate Sulis
Your license is only valid for use in the Asia Pacific region and it looks like you are trying to access it from Europe/Africa which will not work.
I am located currently in UAE as I indicated during the registration of the account. And I am accessing the license from the same location (Dubai, UAE)
Then you might have another issue. I will create a support case so that a specialist can contact you and look into it further.
